Oculus Rift CV1 Facial Interface Replacement
    1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: step 1, image 1 of 1
      • Pull firmly from the top of the headset facial interface to remove the foam frame.
      Ask FixBot
    2. Oculus Rift CV1 Facial Interface Replacement: step 2, image 1 of 1
      • Remove the six T3 4mm screws from the top and bottom edges of the case.
      Ask FixBot
    3. Oculus Rift CV1 Facial Interface Replacement: step 3, image 1 of 1
      • Insert the spudger underneath the edge of the lens on the left or right side.
      • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
      • Repeat for the other side of the frame.
      Ask FixBot
    4. Oculus Rift CV1 Facial Interface Replacement: step 4, image 1 of 3 Oculus Rift CV1 Facial Interface Replacement: step 4, image 2 of 3 Oculus Rift CV1 Facial Interface Replacement: step 4, image 3 of 3
      • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
      • Pull up on the tab with the spudger.
      • Repeat for the corresponding tab on the other lens.
      Ask FixBot
    5. Oculus Rift CV1 Facial Interface Replacement: step 5, image 1 of 1
      • Lift up on the plastic frame around the lens.
      • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
      • Repeat for the frame on the other lens.
      Ask FixBot
    6. Oculus Rift CV1 Facial Interface Replacement: step 6, image 1 of 1
      • Pull up along the outer frame.
      • Remove the facial interface.
      Ask FixBot
Kyle Anderson
250 Reputation
1 Guide authored
Cal Poly, Team S18-G4, White Winter 2019 Member of Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 69
All Time: 6,128
