Up to 20% off select tools
Oculus Rift CV1 Battery Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
105
All Time:
5,148
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide explains how to remove the back panel on the remote and remove the battery from the remote. You do not need any tools for this replacement.
    1. Oculus Rift CV1 Battery Replacement, Battery: step 1, image 1 of 3 Oculus Rift CV1 Battery Replacement, Battery: step 1, image 2 of 3 Oculus Rift CV1 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the back panel by firmly sliding it towards the strap.
      Ask FixBot
    2. Oculus Rift CV1 Battery Replacement: step 2, image 1 of 3 Oculus Rift CV1 Battery Replacement: step 2, image 2 of 3 Oculus Rift CV1 Battery Replacement: step 2, image 3 of 3
      • Push down on the tab under the battery.
      • Firmly slide the battery away from you. The battery should unlatch from its previous position.
      • Once the battery is removed, release the tab.
      Ask FixBot
Author
with
Christian Perry
223 Reputation
2 Guides authored
Cal Poly, Team S18-G4, White Winter 2019 Member of Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 105
All Time: 5,148
