Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓One annoyance of refilling one-time-use vapes is that the e-liquid level indicator remains at zero even when you've refilled it.
Fortunately, with the OVNS Firework it is relatively easy to reset the counter to 100% so you can again judge how much e-liquid remains.
This technique requires a small amount of soldering, so if that's out of your comfort zone, you'll have to settle for continuing to see the counter reading zero.
Note that even though the refill and coil rebuild procedures for the Geek Bar Pulse X are virtually identical to the OVNS Firework, this reset procedure does not work on the Pulse X.
Grasp the mouthpiece with a pair of pliers.
Give it a good, solid twist, left or right doesn't matter.
If the mouthpiece seal came off with the mouthpiece, good, because you'll need to take it off anyway.
Use your tweezers to take out the seal and set it aside.
The rim around the top goes toward the mouthpiece.
Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
Here you can see inside the case where the tab on the mouthpiece lines up.
Turn the power switch to the Off position; no air holes should be visible.
Use your opening tool to lever the power button up. It is only pressed on; there are no adhesives or clips to deal with.
Remove the power button.
The rear cover (the colored part) is clipped on, but the clips are tricky to undo. Start with the top edge and pry it up with your metal opening tool.
In the gap you can now see on the side, slip in an opening pick to keep it open.
Insert an opening pick in one side of the front cover to disengage the two latching tabs on that side.
Insert it far enough to be seen through the rectangular cutouts for the tabs.
Use the point of a spudger to flip up the retaining latch on the display's circuit board.
Start by inserting your pry tool in the bottom seam on one side. Separate the housing slightly.
Flip the vape over and pop the other side loose.
Peel off the Kapton tape securing the battery to the fluid tank.
With the battery freed, the tank can now be separated from the battery and circuit board.
Locate the seam between the tank seal and the lower case seal.
Separate the two seals.
Apply a drop of flux to the negative battery connection.
Use your soldering iron to disconnect the wire.
Use your metal tweezers to short the connection between the negative and positive battery connections on the circuit board. This will drain any residual current and clear the liquid level indicator.
Solder the negative battery wire back onto the circuit board.
The e-liquid level indicator has been reset to 100%.
Of course, the whole point to this is that you're refilling your OVNS Firework vape, so now it's time to use the refill guide and top up the tank.
