ORFELD EV-660-S222 Charging Port Replacement
  1. ORFELD EV-660-S222 Charging Port Replacement, Charging Port: step 1, image 1 of 1
    • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
    Ask FixBot
  2. ORFELD EV-660-S222 Charging Port Replacement: step 2, image 1 of 2 ORFELD EV-660-S222 Charging Port Replacement: step 2, image 2 of 2
    • Place the vacuum on its side, with the screws facing towards you.
    • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
    Ask FixBot
  3. ORFELD EV-660-S222 Charging Port Replacement: step 3, image 1 of 2 ORFELD EV-660-S222 Charging Port Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the sticker connecting the two halves.
    • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
    • Press the blue buttons near the sides of the battery LEDs to remove the top half.
    Ask FixBot
  4. ORFELD EV-660-S222 Charging Port Replacement: step 4, image 1 of 2 ORFELD EV-660-S222 Charging Port Replacement: step 4, image 2 of 2
    • Slide out the charging port.
    Ask FixBot
  5. ORFELD EV-660-S222 Charging Port Replacement: step 5, image 1 of 3 ORFELD EV-660-S222 Charging Port Replacement: step 5, image 2 of 3 ORFELD EV-660-S222 Charging Port Replacement: step 5, image 3 of 3
    • Lift the battery slightly to reveal the pin connectors.
    • Gently remove the four-pin connector connecting the charging port.
    Ask FixBot
2 Guide Comments
I need the diagram how to replace battery the wiring diagram please
Bennie - Reply Share
I need the diagram of a battery pack on a bennett read ev-S
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 653
