ORFELD EV-660-S222 Battery LED Board Replacement
    1. ORFELD EV-660-S222 Battery LED Board Replacement, Battery LED Board: step 1, image 1 of 1
      • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
      Ask FixBot
    2. ORFELD EV-660-S222 Battery LED Board Replacement: step 2, image 1 of 2 ORFELD EV-660-S222 Battery LED Board Replacement: step 2, image 2 of 2
      • Place the vacuum on its side, with the screws facing towards you.
      • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. ORFELD EV-660-S222 Battery LED Board Replacement: step 3, image 1 of 2 ORFELD EV-660-S222 Battery LED Board Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the sticker connecting the two halves.
      • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
      • Press the blue buttons near the sides of the battery LEDs to remove the top half.
      Ask FixBot
    4. ORFELD EV-660-S222 Battery LED Board Replacement: step 4, image 1 of 2 ORFELD EV-660-S222 Battery LED Board Replacement: step 4, image 2 of 2
      • Slide out the charging port.
      Ask FixBot
    5. ORFELD EV-660-S222 Battery LED Board Replacement: step 5, image 1 of 1
      • Lift the battery slightly to reveal the pin connectors.
      • Gently disconnect the six-pin connector that connects to the power button and battery LEDs.
      Ask FixBot
    6. ORFELD EV-660-S222 Battery LED Board Replacement: step 6, image 1 of 3 ORFELD EV-660-S222 Battery LED Board Replacement: step 6, image 2 of 3 ORFELD EV-660-S222 Battery LED Board Replacement: step 6, image 3 of 3
      • Slide out the battery LEDs from the compartment.
      • Remove the plastic LED cover from the LED board.
      Ask FixBot
    7. ORFELD EV-660-S222 Battery LED Board Replacement: step 7, image 1 of 1
      • Desolder the LED board from the wires.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 52
All Time: 1,199
