Up to 20% off select tools
OPPO N1 Screen Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
115
All Time:
6,326
Comments: 2
2 comments on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
After completing the prerequisite guides we will be showing you the step by step process of removing & or disconneting components of the screen.
    1. OPPO N1 Screen Replacement, Rear Case: step 1, image 1 of 1
      • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
      Ask FixBot
    2. OPPO N1 Screen Replacement: step 2, image 1 of 2 OPPO N1 Screen Replacement: step 2, image 2 of 2
      • In the photo we rotated the phone ninety degrees counterclockwise.
      • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
      • The rear case should then come free.
      Ask FixBot
    1. OPPO N1 Screen Replacement, Battery: step 3, image 1 of 2 OPPO N1 Screen Replacement, Battery: step 3, image 2 of 2
      • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
      Ask FixBot
    2. OPPO N1 Screen Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers or your fingers to remove the sliver plates.
      Ask FixBot
    3. OPPO N1 Screen Replacement: step 5, image 1 of 1
      • Remove the black plate with your fingers.
      Ask FixBot
    4. OPPO N1 Screen Replacement: step 6, image 1 of 3 OPPO N1 Screen Replacement: step 6, image 2 of 3 OPPO N1 Screen Replacement: step 6, image 3 of 3
      • Use tweezers or your fingers to pull up the connector tabs.
      Ask FixBot
    5. OPPO N1 Screen Replacement: step 7, image 1 of 2 OPPO N1 Screen Replacement: step 7, image 2 of 2
      • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
      Ask FixBot
    1. OPPO N1 Screen Replacement, Motherboard: step 8, image 1 of 1
      Buy
      • Use tweezers or fingers to remove the three connector tabs.
      Ask FixBot
    2. OPPO N1 Screen Replacement: step 9, image 1 of 2 OPPO N1 Screen Replacement: step 9, image 2 of 2
      • Use tweezers or your fingers to remove the motherboard.
      Ask FixBot
    1. OPPO N1 Screen Replacement, Headphone Jack and Speaker Cover: step 10, image 1 of 1
      • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
      • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
      Ask FixBot
    2. OPPO N1 Screen Replacement: step 11, image 1 of 2 OPPO N1 Screen Replacement: step 11, image 2 of 2
      Buy
      • Use tweezers or your fingers to remove the plastic cover.
      Ask FixBot
    1. OPPO N1 Screen Replacement, Screen: step 12, image 1 of 1
      Buy
      • Use tweezers to disconnect the connector tab.
      Ask FixBot
    2. OPPO N1 Screen Replacement: step 13, image 1 of 1
      • Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
      • Be gentle removing the black strip at this stage. It can easily tear and it must be removed in order to remove the screen.
      Ask FixBot
    3. OPPO N1 Screen Replacement: step 14, image 1 of 3 OPPO N1 Screen Replacement: step 14, image 2 of 3 OPPO N1 Screen Replacement: step 14, image 3 of 3
      • Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
      Ask FixBot
    4. OPPO N1 Screen Replacement: step 15, image 1 of 2 OPPO N1 Screen Replacement: step 15, image 2 of 2
      • Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
      Ask FixBot
10 other people completed this guide.
Author
with
Joshua Stone
1,067 Reputation
5 Guides authored
USF Tampa, Team 13-5, Staggers Fall 2014 Member of USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 115
All Time: 6,326
