Up to 20% off select tools
OPPO N1 Battery Replacement
Views: 25K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
137
All Time:
24,895
Comments: 4
4 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You will learn how to safely and efficiently remove the battery of the Oppo N1 smart phone.
    1. OPPO N1 Battery Replacement, Rear Case: step 1, image 1 of 1
      • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
      Ask FixBot
    2. OPPO N1 Battery Replacement: step 2, image 1 of 2 OPPO N1 Battery Replacement: step 2, image 2 of 2
      • In the photo we rotated the phone ninety degrees counterclockwise.
      • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
      • The rear case should then come free.
      Ask FixBot
    1. OPPO N1 Battery Replacement, Battery: step 3, image 1 of 2 OPPO N1 Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
      Ask FixBot
    2. OPPO N1 Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers or your fingers to remove the sliver plates.
      Ask FixBot
    3. OPPO N1 Battery Replacement: step 5, image 1 of 1
      • Remove the black plate with your fingers.
      Ask FixBot
    4. OPPO N1 Battery Replacement: step 6, image 1 of 3 OPPO N1 Battery Replacement: step 6, image 2 of 3 OPPO N1 Battery Replacement: step 6, image 3 of 3
      • Use tweezers or your fingers to pull up the connector tabs.
      Ask FixBot
    5. OPPO N1 Battery Replacement: step 7, image 1 of 2 OPPO N1 Battery Replacement: step 7, image 2 of 2
      • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
      Ask FixBot
17 other people completed this guide.
Author
with
Joshua Stone
1,067 Reputation
5 Guides authored
USF Tampa, Team 13-5, Staggers Fall 2014 Member of USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Members
72 Guides authored
4 Guide Comments
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
djkleinen - Reply Share
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
simon watling - Reply Share
@simon watling
Omg, so big thanks, man! You just saved many euros for me!
How hard is it to pry the battery off the phone?
arkanista - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 137
All Time: 24,895
