Up to 20% off select tools
OLPC XO-4 Touch Wireless Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
78
All Time:
1,101
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Learn how to install a wireless card into the OLPC XO-4 Touch.
    1. OLPC XO-4 Touch Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside-down, with the handle facing away from you.
      Ask FixBot
    2. OLPC XO-4 Touch Wireless Card Replacement: step 2, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 2, image 2 of 2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Ask FixBot
    3. OLPC XO-4 Touch Wireless Card Replacement: step 3, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 3, image 2 of 2
      • Lift up on the middle of the battery to remove it from the device.
      Ask FixBot
    1. OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: step 4, image 1 of 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: step 4, image 2 of 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: step 4, image 3 of 3
      • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
      • Rotate the screen 180° and remove the other two screws.
      • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
      Ask FixBot
    2. OLPC XO-4 Touch Wireless Card Replacement: step 5, image 1 of 3 OLPC XO-4 Touch Wireless Card Replacement: step 5, image 2 of 3 OLPC XO-4 Touch Wireless Card Replacement: step 5, image 3 of 3
      • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
      • Repeat the step above for the panel on the other side.
      Ask FixBot
    3. OLPC XO-4 Touch Wireless Card Replacement: step 6, image 1 of 1
      • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
      • Gently lift up the lower part of the frame and pull it down to free the screen frame.
      Ask FixBot
    4. OLPC XO-4 Touch Wireless Card Replacement: step 7, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 7, image 2 of 2
      • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
      Ask FixBot
    1. OLPC XO-4 Touch Wireless Card Replacement, Screen: step 8, image 1 of 1
      • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. OLPC XO-4 Touch Wireless Card Replacement: step 9, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 9, image 2 of 2
      • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
      • Carefully lift the screen out.
      Ask FixBot
    3. OLPC XO-4 Touch Wireless Card Replacement: step 10, image 1 of 3 OLPC XO-4 Touch Wireless Card Replacement: step 10, image 2 of 3 OLPC XO-4 Touch Wireless Card Replacement: step 10, image 3 of 3
      • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
      • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
      Ask FixBot
    4. OLPC XO-4 Touch Wireless Card Replacement: step 11, image 1 of 1
      • Remove the screen from the laptop.
      Ask FixBot
    1. OLPC XO-4 Touch Wireless Card Replacement, Back Cover: step 12, image 1 of 1
      • Remove the four 6mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. OLPC XO-4 Touch Wireless Card Replacement: step 13, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 13, image 2 of 2
      • Rotate the top half of the laptop so that the back cover is facing you.
      • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
      • Remove the back cover by gently lifting it off of the laptop.
      Ask FixBot
    1. OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: step 14, image 1 of 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: step 14, image 2 of 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: step 14, image 3 of 3
      • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
      • Gently pull out the two antenna connectors by pulling them away from the motherboard.
      Ask FixBot
    2. OLPC XO-4 Touch Wireless Card Replacement: step 15, image 1 of 1
      • Remove the black 4mm Phillips #1 screw holding the wireless card in.
      Ask FixBot
    3. OLPC XO-4 Touch Wireless Card Replacement: step 16, image 1 of 2 OLPC XO-4 Touch Wireless Card Replacement: step 16, image 2 of 2
      • Remove the wireless card from the laptop by gently sliding it out of its socket.
      Ask FixBot
Author
with
Zach Yasuda
179 Reputation
2 Guides authored
Cal Poly, Team 3-29, Amido Winter 2013 Member of Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 78
All Time: 1,101
