Up to 20% off select tools
OLPC XO-4 Touch Touchpad Controller Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
27
All Time:
984
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken touchpad.
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside-down, with the handle facing away from you.
      Ask FixBot
    2. OLPC XO-4 Touch Touchpad Controller Replacement: step 2, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 2, image 2 of 2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Ask FixBot
    3. OLPC XO-4 Touch Touchpad Controller Replacement: step 3, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 3, image 2 of 2
      • Lift up on the middle of the battery to remove it from the device.
      Ask FixBot
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: step 4, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: step 4, image 2 of 2
      • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
      Ask FixBot
    2. OLPC XO-4 Touch Touchpad Controller Replacement: step 5, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 5, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 5, image 3 of 3
      • Flip the laptop over to its normal position.
      • Lift the two antennas on both sides to unlock the screen.
      • Open the laptop.
      Ask FixBot
    3. OLPC XO-4 Touch Touchpad Controller Replacement: step 6, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 6, image 2 of 2
      • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
      • Gently lift up on the back of the keyboard.
      • Pull the keyboard up far enough to expose the ribbon cable.
      Ask FixBot
    4. OLPC XO-4 Touch Touchpad Controller Replacement: step 7, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 7, image 2 of 2
      • Gently lift up on the black connector to release the ribbon cable.
      • Gently pull the blue plastic tab up and away from the black connector.
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: step 8, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: step 8, image 2 of 2
      • Close and flip the laptop over so you are looking at the battery compartment
      • Remove the five 4mm Phillips #1 screws from inside the battery compartment
      Ask FixBot
    2. OLPC XO-4 Touch Touchpad Controller Replacement: step 9, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 9, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 9, image 3 of 3
      • Flip the laptop over, showing the top of the device.
      • Open the laptop and rotate the screen ninety degrees.
      • Tilt the screen so the lower right corner of the screen is closer to the lower case.
      Ask FixBot
    3. OLPC XO-4 Touch Touchpad Controller Replacement: step 10, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 10, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 10, image 3 of 3
      • Push in and lift up on the keyboard edge of the white handle piece.
      • Pull the piece towards yourself to remove it from the laptop.
      Ask FixBot
    4. OLPC XO-4 Touch Touchpad Controller Replacement: step 11, image 1 of 1
      • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
      Ask FixBot
    5. OLPC XO-4 Touch Touchpad Controller Replacement: step 12, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 12, image 2 of 2
      • Pry off the rear green trim piece.
      Ask FixBot
    6. OLPC XO-4 Touch Touchpad Controller Replacement: step 13, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 13, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 13, image 3 of 3
      • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
      • Slide the green trim pieces away from the screen.
      • This should release the entire bottom portion of the laptop.
      Ask FixBot
    7. OLPC XO-4 Touch Touchpad Controller Replacement: step 14, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 14, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 14, image 3 of 3
      • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
      Ask FixBot
    8. OLPC XO-4 Touch Touchpad Controller Replacement: step 15, image 1 of 2 OLPC XO-4 Touch Touchpad Controller Replacement: step 15, image 2 of 2
      • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
      • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
      Ask FixBot
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: step 16, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: step 16, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: step 16, image 3 of 3
      • You should now be looking at the bottom of the lower case.
      • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
      • Pry off the front and side trim pieces.
      Ask FixBot
    2. OLPC XO-4 Touch Touchpad Controller Replacement: step 17, image 1 of 1
      • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
      Ask FixBot
    3. OLPC XO-4 Touch Touchpad Controller Replacement: step 18, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 18, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 18, image 3 of 3
      • Disconnect the ribbon cable attached to the keyboard compartment.
      • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
      • Remove the mouse buttons controller from the device.
      Ask FixBot
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Touchpad Controller: step 19, image 1 of 1
      • Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
      • Be sure not to lose the silver magnet in the lower right corner of the touchpad assembly.
      Ask FixBot
    2. OLPC XO-4 Touch Touchpad Controller Replacement: step 20, image 1 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 20, image 2 of 3 OLPC XO-4 Touch Touchpad Controller Replacement: step 20, image 3 of 3
      • Remove the silver contact tape from the metal plate.
      • Lift the metal plate off of the touchpad assembly.
      Ask FixBot
Author
with
Theodore Tsanakas
24 Reputation
1 Guide authored
Cal Poly, Team 3-30, Amido Winter 2013 Member of Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 984
