Up to 20% off select tools
OLPC XO-4 Touch Screen Frame Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
98
All Time:
935
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the frame from the screen on your OLPC XO 4.0 Touch.
    1. OLPC XO-4 Touch Screen Frame Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside-down, with the handle facing away from you.
      Ask FixBot
    2. OLPC XO-4 Touch Screen Frame Replacement: step 2, image 1 of 2 OLPC XO-4 Touch Screen Frame Replacement: step 2, image 2 of 2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Ask FixBot
    3. OLPC XO-4 Touch Screen Frame Replacement: step 3, image 1 of 2 OLPC XO-4 Touch Screen Frame Replacement: step 3, image 2 of 2
      • Lift up on the middle of the battery to remove it from the device.
      Ask FixBot
    1. OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: step 4, image 1 of 3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: step 4, image 2 of 3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: step 4, image 3 of 3
      • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
      • Rotate the screen 180° and remove the other two screws.
      • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
      Ask FixBot
    2. OLPC XO-4 Touch Screen Frame Replacement: step 5, image 1 of 3 OLPC XO-4 Touch Screen Frame Replacement: step 5, image 2 of 3 OLPC XO-4 Touch Screen Frame Replacement: step 5, image 3 of 3
      • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
      • Repeat the step above for the panel on the other side.
      Ask FixBot
    3. OLPC XO-4 Touch Screen Frame Replacement: step 6, image 1 of 1
      • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
      • Gently lift up the lower part of the frame and pull it down to free the screen frame.
      Ask FixBot
    4. OLPC XO-4 Touch Screen Frame Replacement: step 7, image 1 of 2 OLPC XO-4 Touch Screen Frame Replacement: step 7, image 2 of 2
      • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
      Ask FixBot
Author
with
Ji Kim
66 Reputation
3 Guides authored
Cal Poly, Team 3-29, Amido Winter 2013 Member of Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 98
All Time: 935
