Up to 20% off select tools
OLPC XO-4 Touch Keyboard Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
93
All Time:
1,702
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken keyboard.
    1. OLPC XO-4 Touch Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside-down, with the handle facing away from you.
      Ask FixBot
    2. OLPC XO-4 Touch Keyboard Replacement: step 2, image 1 of 2 OLPC XO-4 Touch Keyboard Replacement: step 2, image 2 of 2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Ask FixBot
    3. OLPC XO-4 Touch Keyboard Replacement: step 3, image 1 of 2 OLPC XO-4 Touch Keyboard Replacement: step 3, image 2 of 2
      • Lift up on the middle of the battery to remove it from the device.
      Ask FixBot
    1. OLPC XO-4 Touch Keyboard Replacement, Keyboard: step 4, image 1 of 2 OLPC XO-4 Touch Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
      Ask FixBot
    2. OLPC XO-4 Touch Keyboard Replacement: step 5, image 1 of 3 OLPC XO-4 Touch Keyboard Replacement: step 5, image 2 of 3 OLPC XO-4 Touch Keyboard Replacement: step 5, image 3 of 3
      • Flip the laptop over to its normal position.
      • Lift the two antennas on both sides to unlock the screen.
      • Open the laptop.
      Ask FixBot
    3. OLPC XO-4 Touch Keyboard Replacement: step 6, image 1 of 2 OLPC XO-4 Touch Keyboard Replacement: step 6, image 2 of 2
      • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
      • Gently lift up on the back of the keyboard.
      • Pull the keyboard up far enough to expose the ribbon cable.
      Ask FixBot
    4. OLPC XO-4 Touch Keyboard Replacement: step 7, image 1 of 2 OLPC XO-4 Touch Keyboard Replacement: step 7, image 2 of 2
      • Gently lift up on the black connector to release the ribbon cable.
      • Gently pull the blue plastic tab up and away from the black connector.
      • Remove the keyboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Author
with
Michael Kellerman
73 Reputation
3 Guides authored
Cal Poly, Team 3-30, Amido Winter 2013 Member of Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,702
