Up to 20% off select tools
Nvidia Shield Tablet Motherboard Replacement
Views: 11K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
117
All Time:
10,724
Comments: 11
2 comments on steps, 9 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard in your Nvidia Shield Tablet.
    1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: step 1, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: step 1, image 2 of 2
      • First, remove the stylus from your tablet.
      Ask FixBot
    2. Nvidia Shield Tablet Motherboard Replacement: step 2, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 2, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 2, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      Ask FixBot
    3. Nvidia Shield Tablet Motherboard Replacement: step 3, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement: step 3, image 2 of 2
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      Ask FixBot
    1. Nvidia Shield Tablet Motherboard Replacement, Motherboard: step 4, image 1 of 1
      $7.95
      Buy
      • Carefully use the precision tweezers to unplug the ribbon cable.
      • Be sure to have your anti-static wrist strap on for this procedure.
      Ask FixBot
    2. Nvidia Shield Tablet Motherboard Replacement: step 5, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 5, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 5, image 3 of 3
      • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
      Ask FixBot
    3. Nvidia Shield Tablet Motherboard Replacement: step 6, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 6, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 6, image 3 of 3
      • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
      • Use the flat end of the spudger tool to carefully pry up the motherboard.
      • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
      Ask FixBot
    4. Nvidia Shield Tablet Motherboard Replacement: step 7, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement: step 7, image 2 of 2
      • Desolder the positive and negative battery cables from the motherboard.
      • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
      • The motherboard should now come free.
      Ask FixBot
6 other people completed this guide.
Author
with
Molly Bauer
1,478 Reputation
6 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2015 Member of USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Members
72 Guides authored
9 Guide Comments
Where do you obtain a new motherboard?
imprintcave - Reply Share
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Reply Share
where can i buy the motherboard
Gurjot Dhaliwal - Reply Share
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Reply Share
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 117
All Time: 10,724
