Nvidia Shield Tablet Front and Rear Camera Replacement
    1. Nvidia Shield Tablet Front and Rear Camera Replacement, Rear Case: step 1, image 1 of 2 Nvidia Shield Tablet Front and Rear Camera Replacement, Rear Case: step 1, image 2 of 2
      • First, remove the stylus from your tablet.
      Ask FixBot
    2. Nvidia Shield Tablet Front and Rear Camera Replacement: step 2, image 1 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 2, image 2 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 2, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      Ask FixBot
    3. Nvidia Shield Tablet Front and Rear Camera Replacement: step 3, image 1 of 2 Nvidia Shield Tablet Front and Rear Camera Replacement: step 3, image 2 of 2
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      Ask FixBot
    1. Nvidia Shield Tablet Front and Rear Camera Replacement, Speaker: step 4, image 1 of 1
      • Orient your tablet so that the top of the tablet is furthest away from you.
      • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
      Ask FixBot
    2. Nvidia Shield Tablet Front and Rear Camera Replacement: step 5, image 1 of 1
      • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
      Ask FixBot
    3. Nvidia Shield Tablet Front and Rear Camera Replacement: step 6, image 1 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 6, image 2 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 6, image 3 of 3
      • Gently pry the speaker up with the flat end of a spudger.
      • Use a plastic opening tool to peel up the tape covering the speaker wire.
      Ask FixBot
    4. Nvidia Shield Tablet Front and Rear Camera Replacement: step 7, image 1 of 2 Nvidia Shield Tablet Front and Rear Camera Replacement: step 7, image 2 of 2
      $7.95
      Buy
      • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
      • Finally, unplug the power source from your speaker using the precision tweezers.
      • Make sure you are using your anti-static wrist strap.
      Ask FixBot
    1. Nvidia Shield Tablet Front and Rear Camera Replacement, Front and Rear Camera: step 8, image 1 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement, Front and Rear Camera: step 8, image 2 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement, Front and Rear Camera: step 8, image 3 of 3
      • Having removed the speaker, locate the front-facing camera resting just underneath the speaker.
      • The rear-facing camera is on the left side of the tablet and it aligns with the camera hole on the back casing of your tablet.
      Ask FixBot
    2. Nvidia Shield Tablet Front and Rear Camera Replacement: step 9, image 1 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 9, image 2 of 3 Nvidia Shield Tablet Front and Rear Camera Replacement: step 9, image 3 of 3
      Buy
      • Gently unplug each camera using the precision tweezers.
      Ask FixBot
Molly Bauer
1,478 Reputation
6 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2015 Member of USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 39
All Time: 2,578
