Up to 20% off select tools
Nvidia Shield Fan Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
29
Past 30 Days:
122
All Time:
4,259
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 50 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
  • Tweezers
Introduction
Go to step 1 ↓
The Nvidia Shield controller uses an internal fan to help cool its other internal components. Eventually, the fan could require replacement after normal use. Repairing the fan will help to avoid the controller’s internal components overheating, therefore prolonging the life of the device. This guide will explain how to replace the fan using easily found tools, with no special skills needed.
    1. Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 3 of 3
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      Ask FixBot
    2. Nvidia Shield Fan Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Fan Replacement, Remove Green Grill: step 2, image 2 of 2
      • The green grill is not screwed in so it can be pulled right out.
      Ask FixBot
    3. Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 3 of 3
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      Ask FixBot
    4. Nvidia Shield Fan Replacement, Remove Battery Apparatus: step 4, image 1 of 1
      • Pull the battery apparatus out once all cables are removed.
      Ask FixBot
    1. Nvidia Shield Fan Replacement, Removing Fan: step 5, image 1 of 3 Nvidia Shield Fan Replacement, Removing Fan: step 5, image 2 of 3 Nvidia Shield Fan Replacement, Removing Fan: step 5, image 3 of 3
      • Cooling is important for electronics, the last thing they want is to overheat.
      • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
      • Lift the fan free after the screws and cable are removed.
      Ask FixBot
4 other people completed this guide.
Author
with
Marc Perez
545 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 122
All Time: 4,259
