Up to 20% off select tools
Nvidia Shield Display Assembly Replacement
Views: 7.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
104
All Time:
7,636
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
    1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: step 1, image 3 of 3
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      Ask FixBot
    2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Display Assembly Replacement, Remove Green Grill: step 2, image 2 of 2
      • The green grill is not screwed in so it can be pulled right out.
      Ask FixBot
    3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: step 3, image 3 of 3
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      Ask FixBot
    4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: step 4, image 1 of 1
      • Pull the battery apparatus out once all cables are removed.
      Ask FixBot
    1. Nvidia Shield Display Assembly Replacement, Removing Fan: step 5, image 1 of 3 Nvidia Shield Display Assembly Replacement, Removing Fan: step 5, image 2 of 3 Nvidia Shield Display Assembly Replacement, Removing Fan: step 5, image 3 of 3
      • Cooling is important for electronics, the last thing they want is to overheat.
      • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
      • Lift the fan free after the screws and cable are removed.
      Ask FixBot
    1. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: step 6, image 1 of 1
      • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
      • Once removed, the display should be able to be detached.
      Ask FixBot
5 other people completed this guide.
Author
with
Noel Fletcher
116 Reputation
1 Guide authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
72 Guides authored
1 Guide Comment
Where can o get a replacement screen
jorge valenzuela - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 104
All Time: 7,636
