Up to 20% off select tools
Nvidia Shield Controller Motherboard Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
97
All Time:
3,404
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This repair guide shows how to replace the motherboard for a Nvidia Shield Controller Gen 2, manufactured by Nvidia, item model number: 945-12920-2500-000.
The motherboard is a circuit board which connects all the components within a device. If the motherboard is faulty, the controller may not turn on at all.
    1. Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 1 of 3 Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 2 of 3 Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
      Ask FixBot
    2. Nvidia Shield Controller Motherboard Replacement: step 2, image 1 of 2 Nvidia Shield Controller Motherboard Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry open the back frame of the controller.
      Ask FixBot
    3. Nvidia Shield Controller Motherboard Replacement: step 3, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 3, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 3, image 3 of 3
      • Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks.
      • Unplug the power supply cable from the analog stick assembly.
      Ask FixBot
    4. Nvidia Shield Controller Motherboard Replacement: step 4, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 4, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to unplug the rumble motors from the motherboard.
      • Use a pair of tweezers to unplug the battery cable from the motherboard.
      Ask FixBot
    5. Nvidia Shield Controller Motherboard Replacement: step 5, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 5, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 5, image 3 of 3
      • Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame.
      • Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame.
      • Lift out the motherboard from the case.
      Ask FixBot
3 other people completed this guide.
Author
with
Nate Hale
317 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 97
All Time: 3,404
