Up to 20% off select tools
Nvidia Shield Controller Buttons Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
98
All Time:
7,188
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
  • Tweezers
Introduction
Go to step 1 ↓
This guide help you replace your Nvidia Shield Portable buttons if they are faulty or broken. If the buttons on your controller are faulty or broken it is important to replace those buttons as they can interfere with the controllers ability to receive the users inputs (button presses).
Before starting the guide make sure to have a clean work area to disassemble the controller and that you have the replacement buttons.
Feel free to use any replacement parts you are most comfortable with and fit the Nvidia Shield Portable controller.
    1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 3 of 3
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      Ask FixBot
    2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: step 2, image 2 of 2
      • The green grill is not screwed in so it can be pulled right out.
      Ask FixBot
    3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 3 of 3
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      Ask FixBot
    4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: step 4, image 1 of 1
      • Pull the battery apparatus out once all cables are removed.
      Ask FixBot
    1. Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 3 of 3
      • Remove seven 6.5 mm T5 torx screws from the button board.
      • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
      • Remove the button board.
      Ask FixBot
7 other people completed this guide.
Author
with
Daniel Eberhart
379 Reputation
1 Guide authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
72 Guides authored
2 Guide Comments
From where can I get the buttons?
Chirag Khatri - Reply Share
Hey:) I am not sure
Knut Gunnar Walle - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 98
All Time: 7,188
