Up to 20% off select tools
Nvidia Shield Battery Assembly Replacement
Views: 8.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
141
All Time:
8,205
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
  • Tweezers
Introduction
Go to step 1 ↓
This will be a step-by-step guide to remove the battery assembly from the Nvidia Shield. This will need to be performed to install a new battery into the device. The user will not need any special skills beforehand to successfully remove the battery. The user can put the device back together with a new battery installed by following the steps in reverse. Replacing the battery in a Nvidia Shield can help improve the quality of the battery life of the product. If you notice the battery swelling or smoking, before proceeding check out the guide for what to do with a swollen battery.
    1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 3 of 3
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      Ask FixBot
    2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 2 of 2
      • The green grill is not screwed in so it can be pulled right out.
      Ask FixBot
    3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 3 of 3
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      Ask FixBot
    4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: step 4, image 1 of 1
      • Pull the battery apparatus out once all cables are removed.
      Ask FixBot
5 other people completed this guide.
Author
with
Andrew Barbanera
376 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
72 Guides authored
6 Guide Comments
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Reply Share
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Reply Share
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Reply Share
hi! how is this holding up nowadays? i found my old nvidia shield in storage recently and the batteries are completely dead ;;
Canvas - Reply Share
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 141
All Time: 8,205
