Nutribullet Rx #NB-301 Drive Socket Replacement
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: step 1, image 1 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: step 1, image 2 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: step 1, image 3 of 3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
    Ask FixBot
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: step 2, image 1 of 2 Nutribullet Rx #NB-301 Drive Socket Replacement: step 2, image 2 of 2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
    Ask FixBot
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: step 3, image 1 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 3, image 2 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 3, image 3 of 3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
    Ask FixBot
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: step 4, image 1 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 4, image 2 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 4, image 3 of 3
    • Remove the drive socket from the motor.
    Ask FixBot
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: step 5, image 1 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 5, image 2 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 5, image 3 of 3
    • Remove all dust and residue from the area before you replace your new drive socket.
    Ask FixBot
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: step 6, image 1 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 6, image 2 of 3 Nutribullet Rx #NB-301 Drive Socket Replacement: step 6, image 3 of 3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
    Ask FixBot
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: step 7, image 1 of 2 Nutribullet Rx #NB-301 Drive Socket Replacement: step 7, image 2 of 2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
    Ask FixBot
Martin G
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 79
All Time: 1,677
