Nuphy Air75 Keyboard Switch Replacement
    1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: step 1, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: step 1, image 2 of 2
      • Place your keyboard on a clean, well-lit surface.
      • Slide the keyboard power switch to the "off" position.
      Ask FixBot
    2. Nuphy Air75 Keyboard Switch Replacement: step 2, image 1 of 3 Nuphy Air75 Keyboard Switch Replacement: step 2, image 2 of 3 Nuphy Air75 Keyboard Switch Replacement: step 2, image 3 of 3
      • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
      • Pull gently until the key cap comes off.
      • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
      Ask FixBot
    3. Nuphy Air75 Keyboard Switch Replacement: step 3, image 1 of 3 Nuphy Air75 Keyboard Switch Replacement: step 3, image 2 of 3 Nuphy Air75 Keyboard Switch Replacement: step 3, image 3 of 3
      • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
      • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
      • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
      Ask FixBot
    4. Nuphy Air75 Keyboard Switch Replacement: step 4, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement: step 4, image 2 of 2
      • Orient the replacement switch so that the colored, circular module is facing up.
      • Gently press down until you hear an audible click.
      • Place the keycap over the newly installed switch and gently press down.
      Ask FixBot
    5. Nuphy Air75 Keyboard Switch Replacement: step 5, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement: step 5, image 2 of 2
      • Turn the power switch to the "wired" or "wireless" position depending on your setup.
      • Test your keyboard and new key switch.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 210
All Time: 4,120
