Up to 20% off select tools
Numark TT1600 Tone Arm Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
144
All Time:
9,818
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
    1. Numark TT1600 Tone Arm Replacement, Tone Arm: step 1, image 1 of 2 Numark TT1600 Tone Arm Replacement, Tone Arm: step 1, image 2 of 2
      • Flip over the turntable and remove the 9 screws on the outer edges.
      Ask FixBot
    2. Numark TT1600 Tone Arm Replacement: step 2, image 1 of 1
      • Remove the back cover by pulling it apart.
      Ask FixBot
    3. Numark TT1600 Tone Arm Replacement: step 3, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 3, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 3, image 3 of 3
      • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
      • There will be some resistance but continue to pull gently.
      • The clip is located right underneath the audio jacks.
      Ask FixBot
    4. Numark TT1600 Tone Arm Replacement: step 4, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 4, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 4, image 3 of 3
      • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
      Ask FixBot
    5. Numark TT1600 Tone Arm Replacement: step 5, image 1 of 2 Numark TT1600 Tone Arm Replacement: step 5, image 2 of 2
      • Gently pull the wire that you just unscrewed to release it from the clip.
      Ask FixBot
    6. Numark TT1600 Tone Arm Replacement: step 6, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 6, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 6, image 3 of 3
      • Remove the two screws connecting the circuit board to the tone arm.
      Ask FixBot
    7. Numark TT1600 Tone Arm Replacement: step 7, image 1 of 2 Numark TT1600 Tone Arm Replacement: step 7, image 2 of 2
      • Remove the two remaining screws connecting the tone arm to the device.
      Ask FixBot
    8. Numark TT1600 Tone Arm Replacement: step 8, image 1 of 1
      • Flip the turntable back over to the top side.
      • Remove the counter weight located at the back of the tone arm.
      Ask FixBot
    9. Numark TT1600 Tone Arm Replacement: step 9, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 9, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 9, image 3 of 3
      • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
      • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
      Ask FixBot
    10. Numark TT1600 Tone Arm Replacement: step 10, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 10, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 10, image 3 of 3
      • Pick up the tone arm and point the back end of it towards its base.
      • Push the back end of the tone arm into the hole.
      • Flip the turntable over and pull the tone arm all the way through the hole.
      Ask FixBot
3 other people completed this guide.
Author
with
Nikolai
281 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 144
All Time: 9,818
