Numark TT1600 Audio Jacks Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
97
All Time:
1,916
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
    1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: step 1, image 1 of 1
      • Flip over the turntable and remove the nine screws on the outer edges.
      Ask FixBot
    2. Numark TT1600 Audio Jacks Replacement: step 2, image 1 of 2 Numark TT1600 Audio Jacks Replacement: step 2, image 2 of 2
      • Find the audio jacks located on the back side of the turntable.
      • Remove the screw located in between the right and left audio jacks.
      Ask FixBot
    3. Numark TT1600 Audio Jacks Replacement: step 3, image 1 of 1
      • Remove the back cover by pulling it apart.
      Ask FixBot
    4. Numark TT1600 Audio Jacks Replacement: step 4, image 1 of 1
      • Remove the grounding hardware located next to the audio jacks.
      Ask FixBot
    5. Numark TT1600 Audio Jacks Replacement: step 5, image 1 of 2 Numark TT1600 Audio Jacks Replacement: step 5, image 2 of 2
      • Remove the ground screw and washers.
      Ask FixBot
    6. Numark TT1600 Audio Jacks Replacement: step 6, image 1 of 1
      • Remove the remaining nut and washer.
      Ask FixBot
    7. Numark TT1600 Audio Jacks Replacement: step 7, image 1 of 1
      • Remove the screw located on the back panel of the audio jack housing.
      Ask FixBot
    8. Numark TT1600 Audio Jacks Replacement: step 8, image 1 of 3 Numark TT1600 Audio Jacks Replacement: step 8, image 2 of 3 Numark TT1600 Audio Jacks Replacement: step 8, image 3 of 3
      • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
      Ask FixBot
    9. Numark TT1600 Audio Jacks Replacement: step 9, image 1 of 1
      • Gently pull out the audio input jacks from the audio input housing.
      Ask FixBot
2 other people completed this guide.
Nikolai
281 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 97
All Time: 1,916
