Up to 20% off select tools
Numark N4 USB Port Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
118
All Time:
3,429
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Very difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
A faulty USB can cause a host of different problems. This guide is designed to show the reader how to safely replace the USB outlet to restore proper function to your Numark N4 without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
    1. Numark N4 USB Port Replacement, Numark N4 Disassembly: step 1, image 1 of 1
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Numark N4 USB Port Replacement: step 2, image 1 of 1
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Ask FixBot
    3. Numark N4 USB Port Replacement: step 3, image 1 of 1
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Ask FixBot
    4. Numark N4 USB Port Replacement: step 4, image 1 of 1
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Ask FixBot
    5. Numark N4 USB Port Replacement: step 5, image 1 of 1
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Ask FixBot
    6. Numark N4 USB Port Replacement: step 6, image 1 of 1
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Ask FixBot
    1. Numark N4 USB Port Replacement, USB Port: step 7, image 1 of 1
      • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
      Ask FixBot
    2. Numark N4 USB Port Replacement: step 8, image 1 of 1
      • Carefully remove the circuit board from its housing.
      Ask FixBot
    3. Numark N4 USB Port Replacement: step 9, image 1 of 1
      • Locate the USB on the circuit board.
      • Using a soldering station, carefully desolder the connection points to the USB outlet.
      • To review soldering safety and techniques, please visit How To Solder and Desolder Connections.
      Ask FixBot
4 other people completed this guide.
Author
with
Erik Charlton
900 Reputation
5 Guides authored
USF Tampa, Team S13-G11, Cagle Fall 2017 Member of USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Members
72 Guides authored
1 Guide Comment
i we like to get the new board of dis numark n4
daniel benson - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 118
All Time: 3,429
