Up to 20% off select tools
Numark N4 Effect button cover Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,131
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows the reader how to replace the effect button cover. If this plastic part is damaged and doesn't touch the circuit board when pressure is applied, it is likely responsible for an unresponsive effects button.
    1. Numark N4 Effect button cover Replacement, Numark N4 Disassembly: step 1, image 1 of 1
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Numark N4 Effect button cover Replacement: step 2, image 1 of 1
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Ask FixBot
    3. Numark N4 Effect button cover Replacement: step 3, image 1 of 1
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Ask FixBot
    4. Numark N4 Effect button cover Replacement: step 4, image 1 of 1
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Ask FixBot
    5. Numark N4 Effect button cover Replacement: step 5, image 1 of 1
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Ask FixBot
    6. Numark N4 Effect button cover Replacement: step 6, image 1 of 1
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Ask FixBot
    1. Numark N4 Effect button cover Replacement, Effect button cover: step 7, image 1 of 1
      • Locate the top right PCB circuit board.
      Ask FixBot
    2. Numark N4 Effect button cover Replacement: step 8, image 1 of 1
      • Unplug the two ribbon cables as shown.
      Ask FixBot
    3. Numark N4 Effect button cover Replacement: step 9, image 1 of 1
      • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
      Ask FixBot
    4. Numark N4 Effect button cover Replacement: step 10, image 1 of 1
      • Carefully remove the circuit board from its housing.
      Ask FixBot
    5. Numark N4 Effect button cover Replacement: step 11, image 1 of 1
      • Carefully remove the plastic button covers as depicted.
      Ask FixBot
3 other people completed this guide.
Author
with
Erik Charlton
900 Reputation
5 Guides authored
USF Tampa, Team S13-G11, Cagle Fall 2017 Member of USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,131
