Up to 20% off select tools
Numark N4 Audio Jack Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
109
All Time:
1,364
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the audio jack without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
    1. Numark N4 Audio Jack Replacement, Numark N4 Disassembly: step 1, image 1 of 1
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Numark N4 Audio Jack Replacement: step 2, image 1 of 1
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Ask FixBot
    3. Numark N4 Audio Jack Replacement: step 3, image 1 of 1
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Ask FixBot
    4. Numark N4 Audio Jack Replacement: step 4, image 1 of 1
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Ask FixBot
    5. Numark N4 Audio Jack Replacement: step 5, image 1 of 1
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Ask FixBot
    6. Numark N4 Audio Jack Replacement: step 6, image 1 of 1
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Ask FixBot
    1. Numark N4 Audio Jack Replacement, Audio Jack: step 7, image 1 of 1
      • Turn the panel around so that the audio jack is facing forward as shown.
      Ask FixBot
    2. Numark N4 Audio Jack Replacement: step 8, image 1 of 1
      • Using a soldering station, carefully desolder the connection points around the audio jack and remove it.
      • To review soldering safety and techniques, please visit How To Solder and Desolder Connections.
      Ask FixBot
3 other people completed this guide.
Author
with
Erik Charlton
900 Reputation
5 Guides authored
USF Tampa, Team S13-G11, Cagle Fall 2017 Member of USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 109
All Time: 1,364
