NuVision TM800A510L Charging Port Replacement
    1. NuVision TM800A510L Charging Port Replacement, Charging Port: step 1, image 1 of 2 NuVision TM800A510L Charging Port Replacement, Charging Port: step 1, image 2 of 2
      • Use a Heat Gun to loosen the adhesive on the underside of the back cover.
      • Use some prying tools to lift the back cover off of the device.
      • I recommend heating up the device up to 'just barely too hot to touch' and then prying sides up one at a time.
      • Although, you can use either plastic or metal prying tools, metal prying tools may scratch the device. Make sure not to damage power and volume buttons when prying the cover off as well.
      Ask FixBot
    2. NuVision TM800A510L Charging Port Replacement: step 2, image 1 of 1
      • Unscrew the motherboard.
      Ask FixBot
    3. NuVision TM800A510L Charging Port Replacement: step 3, image 1 of 1
      • Make sure all ribbons are disconnected.
      Ask FixBot
    4. NuVision TM800A510L Charging Port Replacement: step 4, image 1 of 2 NuVision TM800A510L Charging Port Replacement: step 4, image 2 of 2
      • Desolder the Motherboard- this will make it easier to get to the charging port without breaking any cords.
      • Flip the Motherboard over and desolder the charging port from Motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 2,397
