NuVision TM800A510L Battery Replacement
    1. NuVision TM800A510L Battery Replacement, Battery: step 1, image 1 of 2 NuVision TM800A510L Battery Replacement, Battery: step 1, image 2 of 2
      • Use a Heat Gun to loosen the adhesive under the backing of the device.
      • Use prying tools to lift up the back of the device to get underneath.
      • I recommend concentrating on one side of the device at a time and making sure the device is 'almost too hot to touch' before you begin using the prying tools.
      • You can use either metal or plastic prying tools. Keep in mind, though, that metal ones may scratch the device.
      Ask FixBot
    2. NuVision TM800A510L Battery Replacement: step 2, image 1 of 2 NuVision TM800A510L Battery Replacement: step 2, image 2 of 2
      • Unlock all of the ribbons that cross or interfere with the battery.
      • Remove the unlocked ribbons if you can- this will make it easier to work with the battery later.
      Ask FixBot
    3. NuVision TM800A510L Battery Replacement: step 3, image 1 of 1
      • Use plastic prying tools to peel up the battery. Metal prying tools may puncture the battery and cause more damage. If you MUST use metal prying tools, go slow.
      • This process may take some time since the battery is held down with adhesive.
      • It is not really recommended to use the Heat Gun on the battery. However, the heat will loosen the adhesive. Therefore, if you decide to use a Heat Gun, apply the heat to the battery from underneath the device (heat the screen).
      Ask FixBot
    4. NuVision TM800A510L Battery Replacement: step 4, image 1 of 1
      • Desolder battery and wires from Motherboard HERE!
      • Once the wires are free, so is the battery. You should be able to replace the battery and its wires in full (as a package deal).
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,424
