NuVision TM1088 Motherboard Replacement
    1. NuVision TM1088 Motherboard Replacement, Rear Cover: step 1, image 1 of 1
      • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
      Ask FixBot
    1. NuVision TM1088 Motherboard Replacement, Motherboard: step 2, image 1 of 1
      • Remove the two plugs for the screen by pulling up and away from the motherboard.
      Ask FixBot
    2. NuVision TM1088 Motherboard Replacement: step 3, image 1 of 1
      • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
      Ask FixBot
    3. NuVision TM1088 Motherboard Replacement: step 4, image 1 of 1
      • Melt solder and remove red and black wires leading to the battery.
      Ask FixBot
    4. NuVision TM1088 Motherboard Replacement: step 5, image 1 of 1
      • Melt the solder on the black and gray wires and remove wires from motherboard.
      Ask FixBot
    5. NuVision TM1088 Motherboard Replacement: step 6, image 1 of 1
      • Melt the solder and remove the red and black wires leading to the speaker.
      Ask FixBot
    6. NuVision TM1088 Motherboard Replacement: step 7, image 1 of 1
      • Remove the four 4 mm Phillips head screws holding in the motherboard.
      Ask FixBot
    7. NuVision TM1088 Motherboard Replacement: step 8, image 1 of 1
      • Lift the motherboard away from the front cover assembly.
      Ask FixBot
Nathaniel Nasman
750 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,975
