NuVision Duo 11 Motherboard Replacement
    1. NuVision Duo 11 Motherboard Replacement, Back Panel: step 1, image 1 of 1
      • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
      • Slide the spudger down each side until you hear numerous clicks.
      • Remove the back panel from the tablet.
      Ask FixBot
    1. NuVision Duo 11 Motherboard Replacement, Battery: step 2, image 1 of 2 NuVision Duo 11 Motherboard Replacement, Battery: step 2, image 2 of 2
      • Carefully remove any pieces of electrical tape that may be adhered to the battery.
      • The tape may be adhered to wires; be sure to pull up the tape slowly.
      Ask FixBot
    2. NuVision Duo 11 Motherboard Replacement: step 3, image 1 of 1
      Ask FixBot
    3. NuVision Duo 11 Motherboard Replacement: step 4, image 1 of 1
      • Gently peel the battery from the front case.
      • You will be met with some resistance, so it is critical that you are very careful.
      • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
      Ask FixBot
    1. NuVision Duo 11 Motherboard Replacement, Speakers: step 5, image 1 of 2 NuVision Duo 11 Motherboard Replacement, Speakers: step 5, image 2 of 2
      Ask FixBot
    2. NuVision Duo 11 Motherboard Replacement: step 6, image 1 of 1
      • Pry the speakers from the casing using a nylon spudger.
      • The speakers may be glued down, so use caution when prying them out.
      Ask FixBot
    1. NuVision Duo 11 Motherboard Replacement, Motherboard: step 7, image 1 of 2 NuVision Duo 11 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Disconnect each ribbon cable from their respective clips on the motherboard.
      Ask FixBot
    2. NuVision Duo 11 Motherboard Replacement: step 8, image 1 of 1
      • Remove the four 4.8 mm screws from the motherboard using a JIS #000 screwdriver.
      Ask FixBot
    3. NuVision Duo 11 Motherboard Replacement: step 9, image 1 of 1
      • Remove the motherboard from the tablet.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Gavin Amaral
377 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 425
