Up to 20% off select tools
NuVision Duo 11 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
69
All Time:
996
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
Have you noticed that your computer's battery might not be as good as good as when you got the device?This replacement guide for the NuVision Duo 11 battery will help you replace that old battery with a new one. This guide will go over soldering, taking apart the battery from the motherboard, and replacement. When reassembling, remember to add a non-corrosive adhesive to the battery so it will stick. This is optional and can be of your choosing, but make sure you can remove it in the future
    1. NuVision Duo 11 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
      • Slide the spudger down each side until you hear numerous clicks.
      • Remove the back panel from the tablet.
      Ask FixBot
    1. NuVision Duo 11 Battery Replacement, Battery: step 2, image 1 of 2 NuVision Duo 11 Battery Replacement, Battery: step 2, image 2 of 2
      • Carefully remove any pieces of electrical tape that may be adhered to the battery.
      • The tape may be adhered to wires; be sure to pull up the tape slowly.
      Ask FixBot
    2. NuVision Duo 11 Battery Replacement: step 3, image 1 of 1
      Ask FixBot
    3. NuVision Duo 11 Battery Replacement: step 4, image 1 of 1
      • Gently peel the battery from the front case.
      • You will be met with some resistance, so it is critical that you are very careful.
      • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
      Ask FixBot
Author
with
Gavin Amaral
377 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 69
All Time: 996
