NuPhy Halo 65 Key Switches Replacement
  1. NuPhy Halo 65 Key Switches Replacement, Key Switches: step 1, image 1 of 3 NuPhy Halo 65 Key Switches Replacement, Key Switches: step 1, image 2 of 3 NuPhy Halo 65 Key Switches Replacement, Key Switches: step 1, image 3 of 3
    • Use a keycap puller to remove the cap covering the switch you want to replace.
    Ask FixBot
  2. NuPhy Halo 65 Key Switches Replacement: step 2, image 1 of 3 NuPhy Halo 65 Key Switches Replacement: step 2, image 2 of 3 NuPhy Halo 65 Key Switches Replacement: step 2, image 3 of 3
    • Latch the switch puller onto the switch, and squeeze lightly for grip.
    • Make sure to apply the puller to the top and bottom edges of the switch.
    • Once secure, pull to remove the switch.
    • During reassembly, don't press too hard on the switch, as this will cause the pins to bend. To fix bent pins, simply grab a pair of small tweezers or pliers and bend them straight, then repeat the process more gently.
    Ask FixBot
Test the switches directly after replacement using an online switch tester, like Key-Test, on your PC.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 194
