NuPhy Halo 65 Back Panel Replacement
  1. NuPhy Halo 65 Back Panel Replacement, Key Switches: step 1, image 1 of 3 NuPhy Halo 65 Back Panel Replacement, Key Switches: step 1, image 2 of 3 NuPhy Halo 65 Back Panel Replacement, Key Switches: step 1, image 3 of 3
    • Use a keycap puller to remove the cap covering the switch you want to replace.
    Ask FixBot
  2. NuPhy Halo 65 Back Panel Replacement: step 2, image 1 of 3 NuPhy Halo 65 Back Panel Replacement: step 2, image 2 of 3 NuPhy Halo 65 Back Panel Replacement: step 2, image 3 of 3
    • Latch the switch puller onto the switch, and squeeze lightly for grip.
    • Make sure to apply the puller to the top and bottom edges of the switch.
    • Once secure, pull to remove the switch.
    • During reassembly, don't press too hard on the switch, as this will cause the pins to bend. To fix bent pins, simply grab a pair of small tweezers or pliers and bend them straight, then repeat the process more gently.
    Ask FixBot
  3. NuPhy Halo 65 Back Panel Replacement, Sound Dampening Silicone: step 3, image 1 of 1
    • Remove eleven 6.8 mm Phillips #000 screws.
    Ask FixBot
  4. NuPhy Halo 65 Back Panel Replacement: step 4, image 1 of 2 NuPhy Halo 65 Back Panel Replacement: step 4, image 2 of 2
    • Using a plastic pry tool, gently separate the aluminum top frame from the bottom base.
    • Unplug both connectors attaching the bottom case to the PCB.
    Ask FixBot
  5. NuPhy Halo 65 Back Panel Replacement: step 5, image 1 of 2 NuPhy Halo 65 Back Panel Replacement: step 5, image 2 of 2
    • Remove the silicone from the back panel.
    Ask FixBot
  6. NuPhy Halo 65 Back Panel Replacement, Back Panel: step 6, image 1 of 1
    • You are left with the back panel.
    • If the panel bends upon removal, simply bend it back into its original shape.
    Ask FixBot
Brandon Shuman
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 44
All Time: 185
