Novation Launchkey mini Mk3 / FLkey mini Disassembly
  1. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The entry: step 1, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The entry: step 1, image 2 of 2
    • This manual goes for both Lauchkey mini MK3 and FLkey, as they are similar in build.
    • Flipping it upside down, shows 4 screws. After removing these screws, the whole thing still feels just as rigid.
    Ask FixBot
  2. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The breaking: step 2, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The breaking: step 2, image 2 of 2
    • Next up are the clippings. I found that starting at a corner works best for me. Then carfully with a pick or screwdriver work yourway around.
    • There's 4 clips on the long sides and 3 on the short sides. Be careful not to open up after undoing all clips.
    Ask FixBot
  3. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The split: step 3, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The split: step 3, image 2 of 2
    • When all clips are undone, and the top and bottom shells are lose, carefully lift the back a little and then slide the top shell towards the key-bed.
    • Carefully flip the top and undo the ribbon cable connecting the key-bed with the top shell.
    Ask FixBot
  4. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 3 of 3
    • The keyboard is undone by unscrewing 9 screws. The keys can then be wiggled out.
    • Mind that the rubber strip has a short and long feet. The short one goes to the front of the board.
    Ask FixBot
  5. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The same suspects: step 5, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The same suspects: step 5, image 2 of 2
    • CY8C4024LQ ARM Microcontroller
    • HC595 bit-shifter
    • 74HC4051D 8-channel analog multiplexer/demultiplexer
    • 74HC165D 8-bit parallel-in/serial out shift register
    • 74HC238D - 3-to-8 line decoder/demultiplexermxic
    • STM32F401RB - STMicroelectronics STM32F401RB - High-performance access line, Arm Cortex-M4 core with DSP and FPU, 128 Kbytes of Flash memory, 84 MHz CPU, ART Accelerator. Yes, apperently it accelerates art :)
    • MXIC MX25L8006E - 3V, 8M-bit[x 1/x 2] CMOS Serial flash memory
    Ask FixBot
  6. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 3 of 3
    • Unscrew the four screw
    • Undo the ribon cable by pulling the black clamp ever so carefull.
    • Remove CPU board.
    Ask FixBot
  7. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The pitcher: step 7, image 1 of 1
    • Undo the ribbon cable.
    • Unscrew 4 screws.
    • Remove the board.
    Ask FixBot
  8. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 3 of 3
    • Unscrew 15 screws.
    • Remove the 8 rotary knob caps from the from of the board, by simply pulling on them. The main board can now be removed.
    • Removing the silicon pads as last, the midi keyboard is now fully disassembled.
    Ask FixBot
I applaud Novation for making a device that is easy to open. No hidden screws and many screw indicators make this easily to repair. Just be careful with the ribbon cables.
What I don't understand is that I had to buy a complete new Novation FLKey to get features that work better with FL Studio. But looking inside, there seems to be no difference in hardware. So why not simply release a FL Studio driver? Maybe the firmware can be snarfed...
9 other people completed this guide.
TheDude
535 Reputation
2 Guides authored
7 Guide Comments
Hello Dude, the driver files you got with your new keyboard could be altered to work with your old keyboard. I had to to play around with a usb audio interface driver once some time ago that i got working like this.
Bill
Misterbill - Reply Share
This article mostly applies to the larger 37 key model as well, but there are 2 screws in the front row that are hidden by the sticky feet. Not in the rear however. So 5 screws in the front row, 4 in the middle, and 2 in the back.
IfitFixItSits - Reply Share
Awesome to hear. I am curious how the keys look like. Because they look like a different construction.
TheDude - Reply Share
I would just add that there is a little black clip on both boards holding the ribbon cable between the two shell pieces. I yanked it out thinking there wasn't a clip and damaged the cable trying to put it back in. No fault of these instructions, they were excellent (as always).
Couldn't find a replacement anywhere online so I ended up just buying the MK4 off of Amazon...
aizo - Reply Share
Hey, TheDude, thanks for the guide! And thanks to IfitFixItSits for the tip about the hidden screws in the FLKey 37. Let me know how I can send pictures to you, if you still want them; I have the keys disassembled for cleaning and it's basically a sandwich of 3 different plastic pieces. Black keys are the top layer, then middle layer is C, E, G, B, finally D, F, A. (Hopefully I've named the keys correctly!)
queenscheapskate - Reply Share
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 136
All Time: 5,322
