Novatel MiFi 2200 Antenna Replacement
    1. Novatel MiFi 2200 Antenna Replacement, Battery: step 1, image 1 of 1
      • Remove the rear cover by pressing down on the cover and pulling it away from the device.
      Ask FixBot
    2. Novatel MiFi 2200 Antenna Replacement: step 2, image 1 of 1
      • Place your finger on the back of the battery located near the edge of the device.
      • Push your finger into the battery and lift up to pop the battery out of the device.
      Ask FixBot
    1. Novatel MiFi 2200 Antenna Replacement, Case: step 3, image 1 of 1
      • Using a metal spudger, pry open the device around the seam between the front and back cover.
      • It may be difficult to split apart, so use force with caution.
      • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
      Ask FixBot
    2. Novatel MiFi 2200 Antenna Replacement: step 4, image 1 of 1
      • Once the seal has been broken all the way around, open the cases using your hands.
      Ask FixBot
    1. Novatel MiFi 2200 Antenna Replacement, Antenna: step 5, image 1 of 1
      • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
      Ask FixBot
    2. Novatel MiFi 2200 Antenna Replacement: step 6, image 1 of 1
      • Carefully pull out the antenna along the edge of the device.
      • There is adhesive applied to the antenna, so it may not easily detach.
      Ask FixBot
    3. Novatel MiFi 2200 Antenna Replacement: step 7, image 1 of 1
      • Reconnect your new antenna to the circuit board in the same position described in step 3.
      Ask FixBot
    4. Novatel MiFi 2200 Antenna Replacement: step 8, image 1 of 1
      • Re-lay antenna around the edge and over the adhesive.
      • The antenna can be fitted back into several small recesses along the groove that it was originally inside.
      Ask FixBot
    5. Novatel MiFi 2200 Antenna Replacement: step 9, image 1 of 3 Novatel MiFi 2200 Antenna Replacement: step 9, image 2 of 3 Novatel MiFi 2200 Antenna Replacement: step 9, image 3 of 3
      • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
      • Snap the two halves together along the adhesive line to reconnect it as it previously was.
      Ask FixBot
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
Carissah
147 Reputation
2 Guides authored
Cal Poly, Team 7-36, Maness Spring 2012 Member of Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 851
