Novatel MiFi 2 4G LTE Hotspot SD Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
50
All Time:
455
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to replace a faulty SD Card in your Novatel Hotspot device. This requires opening the rubber flap and removing the old SD Card.
Note: This guide does not feature an actual SD Card.
    1. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: step 1, image 1 of 2 Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: step 1, image 2 of 2
      • Unplug the charger from your Novatel Hotspot device.
      • Place the Novatel Hotspot device face down on a flat, clean surface.
      • Locate the rubber SD Card cover on the bottom left hand side of the device. The cover is labeled “Micro SD.”
      Ask FixBot
    2. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement: step 2, image 1 of 1
      • Open the SD Card cover by placing your finger on the top of the rubber cover and pulling it down.
      • Remove the faulty SD card from its slot by sliding it out with your finger.
      • This guide does not feature an actual SD Card.
      Ask FixBot
GerardFoley
351 Reputation
4 Guides authored
Marist, Team S1-G5, Chaterdon Fall 2018 Member of Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 50
All Time: 455
