Up to 20% off select tools
Nostalgia GCM200 Power Cable Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
87
All Time:
798
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Parts
Tools
Introduction
Go to step 1 ↓
This is a replacement guide that teaches you how to replce power cable for Nostalgia GCM-200.
    1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: step 1, image 1 of 2 Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: step 1, image 2 of 2
      • Remove the two 1.3 mm Phillips #2 screws.
      • Remove the S6 spanner screw.
      • Carefully place these three screws somewhere safe to use later in reassembly.
      Ask FixBot
    2. Nostalgia GCM200 Power Cable Replacement: step 2, image 1 of 1
      • Split the device in half to expose the internal parts of the device.
      • Again, there are two more Phillips screws to remove.
      Ask FixBot
    3. Nostalgia GCM200 Power Cable Replacement: step 3, image 1 of 1
      • Remove the two screws from both sides of the heating coil.
      Ask FixBot
    1. Nostalgia GCM200 Power Cable Replacement, Power Cable: step 4, image 1 of 1
      • Remove (flexible) plastic sleeves from the inside end of the power cable.
      • You might want to use force, pull out while shaking it.
      Ask FixBot
Author
with
Praful Busa
267 Reputation
2 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2017 Member of UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 87
All Time: 798
