Nostalgia GCM200 Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
91
All Time:
589
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
It's a simple process to replace the parts of this device. Once you have the device opened, these items can be changed: power button, power cable, heating bowl, and heating coil/pan Etc.
Parts
Tools
    1. Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: step 1, image 1 of 2 Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: step 1, image 2 of 2
      • Remove the two 1.3 mm Phillips #2 screws.
      • Remove the S6 spanner screw.
      • Carefully place these three screws somewhere safe to use later in reassembly.
      Ask FixBot
    2. Nostalgia GCM200 Power Button Replacement: step 2, image 1 of 1
      • Split the device in half to expose the internal parts of the device.
      • Again, there are two more Phillips screws to remove.
      Ask FixBot
    3. Nostalgia GCM200 Power Button Replacement: step 3, image 1 of 1
      • Remove the two screws from both sides of the heating coil.
      Ask FixBot
    1. Nostalgia GCM200 Power Button Replacement, Power Button: step 4, image 1 of 1
      • Split the device into 2 parts to change the power button.
      • Power button hold the other parts, so be careful.
      Ask FixBot
    2. Nostalgia GCM200 Power Button Replacement: step 5, image 1 of 1
      • Remove (flexible) plastic sleeves from the inside end of the power cable.
      • You might want to use force, pull out while shaking it.
      • Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
      Ask FixBot
    3. Nostalgia GCM200 Power Button Replacement: step 6, image 1 of 1
      • Depress the little tab inside the top portion of the device to remove the On/Off switch.
      Ask FixBot
    4. Nostalgia GCM200 Power Button Replacement: step 7, image 1 of 1
      • Replace the power button, and put the plastic sleeves in the original position.
      • Great, you just finished replacing power button
      Ask FixBot
    5. Nostalgia GCM200 Power Button Replacement: step 8, image 1 of 1
      • To reassemble your device, follow these instructions in reverse order.
      Ask FixBot
This guide will help you to replace the power button
3 other people completed this guide.
Xingdi Zhou
466 Reputation
3 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2017 Member of UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 91
All Time: 589
