Nostalgia Electrics PCM805 Stand Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
93
All Time:
929
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the stands on the bottom of the device if they are missing or damaged.
Parts
    1. Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: step 1, image 1 of 2 Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: step 1, image 2 of 2
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      Ask FixBot
    2. Nostalgia Electrics PCM805 Stand Replacement: step 2, image 1 of 1
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      Ask FixBot
    1. Nostalgia Electrics PCM805 Stand Replacement, Stand: step 3, image 1 of 1
      • Locate the four 10mm Phillips #02 screws on the inside of the panel.
      Ask FixBot
    2. Nostalgia Electrics PCM805 Stand Replacement: step 4, image 1 of 3 Nostalgia Electrics PCM805 Stand Replacement: step 4, image 2 of 3 Nostalgia Electrics PCM805 Stand Replacement: step 4, image 3 of 3
      • Remove the screw of the foot you plan to replace.
      • Place your finger on the back of the the foot you are unscrewing for support.
      Ask FixBot
Carlton
672 Reputation
5 Guides authored
USF Tampa, Team 3-5, Hickman Winter 2015 Member of USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 93
All Time: 929
