Nostalgia Electrics PCM805 Power Switch Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
87
All Time:
2,483
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the switch if the device will not turn on when receiving power.
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: step 1, image 1 of 2 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: step 1, image 2 of 2
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      Ask FixBot
    2. Nostalgia Electrics PCM805 Power Switch Replacement: step 2, image 1 of 1
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      Ask FixBot
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: step 3, image 1 of 1
      • Locate the switch/wire assembly inside the device.
      Ask FixBot
    2. Nostalgia Electrics PCM805 Power Switch Replacement: step 4, image 1 of 1
      • Pull back the insulation sleeves to expose the connector heads.
      Ask FixBot
    3. Nostalgia Electrics PCM805 Power Switch Replacement: step 5, image 1 of 2 Nostalgia Electrics PCM805 Power Switch Replacement: step 5, image 2 of 2
      • Note the color of each wire and the order you remove them.
      • Using a pair of pliers, firmly grip the base of the wire.
      • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
      • Pull the wire straight out of the switch.
      • Repeat this step for each wire.
      Ask FixBot
    4. Nostalgia Electrics PCM805 Power Switch Replacement: step 6, image 1 of 2 Nostalgia Electrics PCM805 Power Switch Replacement: step 6, image 2 of 2
      • Using pliers, pinch tabs at the top and bottom of switch.
      • While pinching the tabs, push the switch until the tabs are on the outside of the device.
      Ask FixBot
    5. Nostalgia Electrics PCM805 Power Switch Replacement: step 7, image 1 of 2 Nostalgia Electrics PCM805 Power Switch Replacement: step 7, image 2 of 2
      • Remove the switch from the device.
      Ask FixBot
Carlton
672 Reputation
5 Guides authored
USF Tampa, Team 3-5, Hickman Winter 2015 Member of USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Members
96 Guides authored
1 Guide Comment
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 87
All Time: 2,483
