Nortel Networks i2004 IP Back Cover Replacement
    1. Nortel Networks i2004 IP Back Cover Replacement, Back Cover: step 1, image 1 of 3 Nortel Networks i2004 IP Back Cover Replacement, Back Cover: step 1, image 2 of 3 Nortel Networks i2004 IP Back Cover Replacement, Back Cover: step 1, image 3 of 3
      • Flip the phone over to view the back.
      • Remove the power and phone cords.
      Ask FixBot
    2. Nortel Networks i2004 IP Back Cover Replacement: step 2, image 1 of 1
      • Remove the seven 8mm Phillips #2 screws.
      Ask FixBot
    3. Nortel Networks i2004 IP Back Cover Replacement: step 3, image 1 of 2 Nortel Networks i2004 IP Back Cover Replacement: step 3, image 2 of 2
      • Lift up the back cover slowly because there are still wires attached to the circuit board.
      • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
      Ask FixBot
    4. Nortel Networks i2004 IP Back Cover Replacement: step 4, image 1 of 1
      • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
      Ask FixBot
    5. Nortel Networks i2004 IP Back Cover Replacement: step 5, image 1 of 2 Nortel Networks i2004 IP Back Cover Replacement: step 5, image 2 of 2
      • Remove the six 8mm Phillips #2 screws.
      • Pull the speaker phone cover straight up.
      Ask FixBot
2 other people completed this guide.
Elizabeth
175 Reputation
3 Guides authored
Cal Poly, Team 10-35, Amido Winter 2012 Member of Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,645
