Nook Tablet Speaker Assembly Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
27
All Time:
2,592
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Nook Tablet speaker assembly component is not working properly or is broken, this guide will take you through the process of taking apart the device down to the motherboard. Then you will replace the speaker assembly with a new speaker assembly to allow for proper functioning again.
Tools
    1. Nook Tablet Speaker Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Flip the Nook over.
      Ask FixBot
    2. Nook Tablet Speaker Assembly Replacement: step 2, image 1 of 2 Nook Tablet Speaker Assembly Replacement: step 2, image 2 of 2
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      Ask FixBot
    3. Nook Tablet Speaker Assembly Replacement: step 3, image 1 of 2 Nook Tablet Speaker Assembly Replacement: step 3, image 2 of 2
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      Ask FixBot
    4. Nook Tablet Speaker Assembly Replacement: step 4, image 1 of 2 Nook Tablet Speaker Assembly Replacement: step 4, image 2 of 2
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      Ask FixBot
    5. Nook Tablet Speaker Assembly Replacement: step 5, image 1 of 1
      • Pull the back panel off the Nook.
      Ask FixBot
    1. Nook Tablet Speaker Assembly Replacement, Screen Bezel: step 6, image 1 of 2 Nook Tablet Speaker Assembly Replacement, Screen Bezel: step 6, image 2 of 2
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      Ask FixBot
    2. Nook Tablet Speaker Assembly Replacement: step 7, image 1 of 2 Nook Tablet Speaker Assembly Replacement: step 7, image 2 of 2
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      Ask FixBot
    1. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: step 8, image 1 of 2 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: step 8, image 2 of 2
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      Ask FixBot
    1. Nook Tablet Speaker Assembly Replacement, Midframe: step 9, image 1 of 1
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      Ask FixBot
    2. Nook Tablet Speaker Assembly Replacement: step 10, image 1 of 2 Nook Tablet Speaker Assembly Replacement: step 10, image 2 of 2
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      Ask FixBot
    1. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: step 11, image 1 of 1
      • Using your hands pull the square speaker assembly component off the motherboard.
      Ask FixBot
    2. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: step 12, image 1 of 1
      • Now place the new speaker assembly component back in the same square location.
      • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
      Ask FixBot
Josh Fisher
9 Reputation
1 Guide authored
Cal Poly, Team 1-4, Propen Fall 2012 Member of Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 2,592
