Up to 20% off select tools
Nook Tablet Display Replacement
Views: 33K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
121
All Time:
33,437
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will show easy ways to access the nook tablet visual display, replace the screen or reconnect the display if it is not working properly.
    1. Nook Tablet Display Replacement, Back Cover: step 1, image 1 of 1
      • Flip the Nook over.
      Ask FixBot
    2. Nook Tablet Display Replacement: step 2, image 1 of 2 Nook Tablet Display Replacement: step 2, image 2 of 2
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      Ask FixBot
    3. Nook Tablet Display Replacement: step 3, image 1 of 2 Nook Tablet Display Replacement: step 3, image 2 of 2
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      Ask FixBot
    4. Nook Tablet Display Replacement: step 4, image 1 of 2 Nook Tablet Display Replacement: step 4, image 2 of 2
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      Ask FixBot
    5. Nook Tablet Display Replacement: step 5, image 1 of 1
      • Pull the back panel off the Nook.
      Ask FixBot
    1. Nook Tablet Display Replacement, Screen Bezel: step 6, image 1 of 2 Nook Tablet Display Replacement, Screen Bezel: step 6, image 2 of 2
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      Ask FixBot
    2. Nook Tablet Display Replacement: step 7, image 1 of 2 Nook Tablet Display Replacement: step 7, image 2 of 2
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      Ask FixBot
    1. Nook Tablet Display Replacement, Disconnect the Battery: step 8, image 1 of 2 Nook Tablet Display Replacement, Disconnect the Battery: step 8, image 2 of 2
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      Ask FixBot
    1. Nook Tablet Display Replacement, Midframe: step 9, image 1 of 1
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      Ask FixBot
    2. Nook Tablet Display Replacement: step 10, image 1 of 2 Nook Tablet Display Replacement: step 10, image 2 of 2
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      Ask FixBot
    1. Nook Tablet Display Replacement, Display: step 11, image 1 of 2 Nook Tablet Display Replacement, Display: step 11, image 2 of 2
      • Orient the mother board as shown, so that the screen is facing downwards.
      • Grab the corner of the orange strip on the right side of the mother board as shown.
      • The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
      • The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
      Ask FixBot
    2. Nook Tablet Display Replacement: step 12, image 1 of 3 Nook Tablet Display Replacement: step 12, image 2 of 3 Nook Tablet Display Replacement: step 12, image 3 of 3
      • The orange strip will still be attached at this point
      • Insert the end of a flat head screw driver between the connection of the strip and mother board and pry upward.
      • Grab the strip and gently pull upward to finish the disconnection.
      Ask FixBot
    3. Nook Tablet Display Replacement: step 13, image 1 of 2 Nook Tablet Display Replacement: step 13, image 2 of 2
      • On the left side of the motherboard, you will see another orange strip, this one is taped down to the motherboard.
      • Remove the tape.
      Ask FixBot
    4. Nook Tablet Display Replacement: step 14, image 1 of 3 Nook Tablet Display Replacement: step 14, image 2 of 3 Nook Tablet Display Replacement: step 14, image 3 of 3
      • After the tape has been removed, the strip will still be attached to the motherboard by the hinge pictured here.
      • Slide the tip of a flat head screwdriver under the hinge and pry the hinge upward.
      • The orange strip should now be detached from the mother board.
      Ask FixBot
    5. Nook Tablet Display Replacement: step 15, image 1 of 3 Nook Tablet Display Replacement: step 15, image 2 of 3 Nook Tablet Display Replacement: step 15, image 3 of 3
      • The screen is adhered to the mother board at the screw holes marked
      • Break the adhesion by inserting the edge of a flat head screwdriver inbetween the motherboard and the pieces of the screen at the marked holes
      • Lift the screen from the display.
      Ask FixBot
12 other people completed this guide.
Author
with
Michael Mooney
291 Reputation
1 Guide authored
Cal Poly, Team 1-4, Propen Fall 2012 Member of Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Members
84 Guides authored
2 Guide Comments
Where can one get a replacement screen for the glow-light first model?
Hank - Reply Share
I need battery
Mister A - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 121
All Time: 33,437
