Up to 20% off select tools
Nook Tablet Back Cover Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
133
All Time:
6,913
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Easy
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to remove the back cover revealing the battery. This will allow you to access the inside of the nook tablet and will act as prerequisite for most of the other guides
    1. Nook Tablet Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Flip the Nook over.
      Ask FixBot
    2. Nook Tablet Back Cover Replacement: step 2, image 1 of 2 Nook Tablet Back Cover Replacement: step 2, image 2 of 2
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      Ask FixBot
    3. Nook Tablet Back Cover Replacement: step 3, image 1 of 2 Nook Tablet Back Cover Replacement: step 3, image 2 of 2
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      Ask FixBot
    4. Nook Tablet Back Cover Replacement: step 4, image 1 of 2 Nook Tablet Back Cover Replacement: step 4, image 2 of 2
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      Ask FixBot
    5. Nook Tablet Back Cover Replacement: step 5, image 1 of 1
      • Pull the back panel off the Nook.
      Ask FixBot
To reassemble your device, line up the piece that was removed with how it was on before and then just firmly press down till it snaps into place.
5 other people completed this guide.
Author
with
Jacob Metzinger
89 Reputation
2 Guides authored
Cal Poly, Team 1-4, Propen Fall 2012 Member of Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 133
All Time: 6,913
