Up to 20% off select tools
Nook HD Back and Front Casing Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
90
All Time:
3,236
Comments: 1
1 comment on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
We will take apart the Nook HD's paneling to reveal the internal components. This guide may be used as a prerequisite for other Nook HD guides.
    1. Nook HD Back and Front Casing Replacement, Case: step 1, image 1 of 3 Nook HD Back and Front Casing Replacement, Case: step 1, image 2 of 3 Nook HD Back and Front Casing Replacement, Case: step 1, image 3 of 3
      • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
      • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
      • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
      Ask FixBot
    2. Nook HD Back and Front Casing Replacement: step 2, image 1 of 2 Nook HD Back and Front Casing Replacement: step 2, image 2 of 2
      • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
      Ask FixBot
    3. Nook HD Back and Front Casing Replacement: step 3, image 1 of 3 Nook HD Back and Front Casing Replacement: step 3, image 2 of 3 Nook HD Back and Front Casing Replacement: step 3, image 3 of 3
      • Slowly pull the back casing away from the screen and motherboard.
      • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
      Ask FixBot
    4. Nook HD Back and Front Casing Replacement: step 4, image 1 of 3 Nook HD Back and Front Casing Replacement: step 4, image 2 of 3 Nook HD Back and Front Casing Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
      Ask FixBot
6 other people completed this guide.
Author
with
Connor Pickert
320 Reputation
2 Guides authored
Cal Poly, Team 3-43, Maness Spring 2014 Member of Cal Poly, Team 3-43, Maness Spring 2014
CPSU-MANESS-S14S3G43
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 90
All Time: 3,236
