Up to 20% off select tools
Nook HD+ Volume/Power Buttons Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
71
All Time:
591
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the Nook HD+ volume and power button housings in 4 easy to understand steps. The tools needed to replace this piece of the Nook HD+ are the plastic opening tool, a T5 screwdriver, and tweezers.
No hazards are present in this guide, but be mindful of how rough the motherboard and ribbons are treated.
    1. Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: step 1, image 1 of 3 Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: step 1, image 2 of 3 Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: step 1, image 3 of 3
      • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
      • Pop up all plastic tabs that secure the frame to the chassis.
      Ask FixBot
    2. Nook HD+ Volume/Power Buttons Replacement: step 2, image 1 of 3 Nook HD+ Volume/Power Buttons Replacement: step 2, image 2 of 3 Nook HD+ Volume/Power Buttons Replacement: step 2, image 3 of 3
      • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing.
      • Disconnect battery from motherboard.
      • Remove back casing.
      Ask FixBot
    3. Nook HD+ Volume/Power Buttons Replacement: step 3, image 1 of 2 Nook HD+ Volume/Power Buttons Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
      • Use tweezers to lift the flaps.
      Ask FixBot
    4. Nook HD+ Volume/Power Buttons Replacement: step 4, image 1 of 2 Nook HD+ Volume/Power Buttons Replacement: step 4, image 2 of 2
      • Remove three 5.0 mm Torx T5 screws that secure buttons to chassis.
      • Slide button assembly up and out of the chassis.
      Ask FixBot
Author
with
Brennan Holcombe
256 Reputation
2 Guides authored
IUPUI, Team 3-3, Harley Spring 2022 Member of IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 71
All Time: 591
