Up to 20% off select tools
Nook HD+ Top Frame Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
104
All Time:
1,391
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the cover of your Nook HD+.
    1. Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 1 of 3 Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 2 of 3 Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 3 of 3
      • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
      • Note there will be glue and be careful not to break the clips.
      Ask FixBot
    2. Nook HD+ Top Frame Replacement, Add New Glue: step 2, image 1 of 1
      • Apply glue round the inside perimeter of the new frame on the clip side.
      Ask FixBot
    3. Nook HD+ Top Frame Replacement: step 3, image 1 of 1
      • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
      • Run finger around the entire frame making sure all the clips are in place.
      • Let glue dry.
      Ask FixBot
Author
with
Alex Pelicas
283 Reputation
2 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 104
All Time: 1,391
