Up to 20% off select tools
Nook HD+ Speaker Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
98
All Time:
1,361
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
Steps to replace a broken speaker in the Nook HD+ tablet.
    1. Nook HD+ Speaker Replacement, Take off the Top Frame: step 1, image 1 of 1
      • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
      • Pry open the front frame.
      Ask FixBot
    2. Nook HD+ Speaker Replacement, Remove the screws: step 2, image 1 of 2 Nook HD+ Speaker Replacement, Remove the screws: step 2, image 2 of 2
      • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
      Ask FixBot
    3. Nook HD+ Speaker Replacement, Remove the Battery: step 3, image 1 of 2 Nook HD+ Speaker Replacement, Remove the Battery: step 3, image 2 of 2
      • Carefully remove the bottom frame from center chassis.
      • Detach the battery ribbon from the motherboard.
      • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
      Ask FixBot
    4. Nook HD+ Speaker Replacement, Unscrew the speaker: step 4, image 1 of 1
      • In the bottom left hand corner remove the 3 screws that at attached to the speaker
      • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
      • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
      Ask FixBot
2 other people completed this guide.
Author
with
Alex Pelicas
283 Reputation
2 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
60 Guides authored
1 Guide Comment
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 98
All Time: 1,361
