Up to 20% off select tools
Nook HD+ Motherboard Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
61
All Time:
701
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the Nook HD+ motherboard in 7 easy to understand steps. The tools needed to replace this piece of the Nook HD+ are the plastic opening tool, a T5 screwdriver, and tweezers.
No hazards are present in this guide, but be mindful of how rough the motherboard and ribbons are treated.
    1. Nook HD+ Motherboard Replacement, Motherboard: step 1, image 1 of 3 Nook HD+ Motherboard Replacement, Motherboard: step 1, image 2 of 3 Nook HD+ Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
      • Pop up all plastic tabs that secure the frame to the chassis.
      Ask FixBot
    2. Nook HD+ Motherboard Replacement: step 2, image 1 of 3 Nook HD+ Motherboard Replacement: step 2, image 2 of 3 Nook HD+ Motherboard Replacement: step 2, image 3 of 3
      • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
      • Disconnect battery from motherboard.
      • Remove back casing.
      Ask FixBot
    3. Nook HD+ Motherboard Replacement: step 3, image 1 of 2 Nook HD+ Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
      • Use tweezers to lift the flaps.
      Ask FixBot
    4. Nook HD+ Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
      • No tool is needed. Gently pull on the wires until the piece disconnects.
      Ask FixBot
    5. Nook HD+ Motherboard Replacement: step 5, image 1 of 1
      • Disconnect antenna from motherboard by pulling up with slight force.
      Ask FixBot
    6. Nook HD+ Motherboard Replacement: step 6, image 1 of 2 Nook HD+ Motherboard Replacement: step 6, image 2 of 2
      • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
      • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
      Ask FixBot
    7. Nook HD+ Motherboard Replacement: step 7, image 1 of 2 Nook HD+ Motherboard Replacement: step 7, image 2 of 2
      • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
      • Remove the motherboard.
      Ask FixBot
Author
with
Brennan Holcombe
256 Reputation
2 Guides authored
IUPUI, Team 3-3, Harley Spring 2022 Member of IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 61
All Time: 701
