Up to 20% off select tools
Nook HD+ Antenna Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
88
All Time:
1,749
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This replacement guide for the Nook HD+ requires the use of a soldering iron which should not be used by children, and if mishandled could lead to extreme injury.
    1. Nook HD+ Antenna Replacement, Antenna: step 1, image 1 of 1
      • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
      Ask FixBot
    2. Nook HD+ Antenna Replacement, Remove the screws: step 2, image 1 of 2 Nook HD+ Antenna Replacement, Remove the screws: step 2, image 2 of 2
      • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
      Ask FixBot
    3. Nook HD+ Antenna Replacement, Remove the chassis: step 3, image 1 of 2 Nook HD+ Antenna Replacement, Remove the chassis: step 3, image 2 of 2
      • Carefully remove the center chassis from the bottom frame.
      Ask FixBot
    4. Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 1 of 3 Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 2 of 3 Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 3 of 3
      • Detach the battery ribbon from the motherboard.
      Ask FixBot
    5. Nook HD+ Antenna Replacement, Flip the center chassis: step 5, image 1 of 1
      • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
      Ask FixBot
    6. Nook HD+ Antenna Replacement, Remove the antenna part 1: step 6, image 1 of 2 Nook HD+ Antenna Replacement, Remove the antenna part 1: step 6, image 2 of 2
      • Remove the wire from the attachment on the motherboard (this wire un-clips).
      Ask FixBot
    7. Nook HD+ Antenna Replacement, Remove the antenna part 2: step 7, image 1 of 2 Nook HD+ Antenna Replacement, Remove the antenna part 2: step 7, image 2 of 2
      • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
      Ask FixBot
    8. Nook HD+ Antenna Replacement, Place new antenna.: step 8, image 1 of 2 Nook HD+ Antenna Replacement, Place new antenna.: step 8, image 2 of 2
      • Replace new antenna following all the steps in reverse.
      Ask FixBot
Author
with
Elijah Gonsalves
1,049 Reputation
3 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 88
All Time: 1,749
