Up to 20% off select tools
Nook BNRV300 Power Button Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
68
All Time:
1,634
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 seconds
Difficulty: Very easy
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide describes the removal of the power button from the Nook BNRV300 device. This device is also called the “Nook Simple Touch.”
Removing the power button enables the user to replace the button if the Nook device is not responding. It also allows users top open the back cover of the Nook for access to the device’s components.
Check out this troubleshooting guide on the buttons before opening the device.
    1. Nook BNRV300 Power Button Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Power Button Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
      • Turn the Nook over to find the power button along the back upper edge.
      • Wedge the spudger between the top of the power button and the upper edge of the device.
      • Push the tool down to pry the button up and off.
      Ask FixBot
    2. Nook BNRV300 Power Button Replacement: step 2, image 1 of 1
      • Using your fingers, take off the power button.
      Ask FixBot
Author
with
Alisyn Waite
417 Reputation
3 Guides authored
2 Guide Comments
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Reply Share
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 1,634
